Hi Often it,s more of an adjustment than anything else... The rollers are plastic, normally, so maybe check the alignment of the doors You may be able to get new rollers, if required. Regards Peter
To be honest, I've no idea, got it for my bike. I'm sure it will all be very similar, just make sure you get a white one!
Give 'em a quick squirt with ----> http://www.screwfix.com/p/wd-40-specialist-silicone-lubricant-400ml/86394
Doh! Hi Gummo... That'll teach me to read twice and reply once!! I misread, assumed you were lubing fixed axle's of nylon rollers NOT the track. If that is the case, silicon is insoluble in water so dry would be very advisable. BUT, after rereading... If your shower doors use something like static nylon/plastic runners in say an aluminium track? I'd go for a dry PTFE ---> http://www.screwfix.com/p/wd-40-dry-ptfe-lubricant-400ml/36613 or possibly http://www.screwfix.com/p/wd-40-specialist-hp-ptfe-lubricant-400ml/48847 Both are pretty slippery critters, so go easy on the trigger as you only need a thin coating to reduce any friction to a minimum... Seeing as it's a shower, I should add a disclaimer regarding slippage, trapped fingers and/or other appendages due to the use of the afore mentioned products
Hi there, I agree with Peter, most of the times its just an alignment issue so you might want to check that first. Any dry silicon spray lube will be fine, just make sure you dont use petroleum based lubes or WD40. Those wet type lubes attract dirt and dust and get very messy.
Sorry if I reported an actual fault with the doors - I had been reading the care instructions which recommended occasional lubrication. I'll go for the WD40 silicone spray.
