Hello, I have square edged skirting with a single line which I think is one of the easier ones to install. Just wanted to check. I had someone around who suggested that for this type of skirting you could eliminate doing 45 degree cuts at a number of the edges and instead just have the two pieces touch each other at the 90 degree angle. (kinda like > L) I've looked online and I cannot see this method used much as was curious whether it is just a way of rushing it a bit. Thanks,
Normally you mitre an exterior corner and scribe an internal, as you have nothing to scribe then internals could be butted.
Ok, apart from saving time, I can't see any reason not to paint my living room ceiling with a 1 1/2in wide roller.
No reason why not as long as you use Valspar paint, I hear that you can get a lot for your money at present!
