Can anyone recommend what's best to glue the 3mm plastic Howdens edging on I have normal evostik and solvent free Evo which Howdens recommend but when I've fitted them before diddnt think it was great Thanks Aron
Howdens squared edged worktops are notorious. If you search through the archives on this site you will see quite a few posts on it. You would probably be better with old fashioned Evo Stick contact adhesive
Fitted someHowdens square edge tops earlier in the year, was just standard laminate edging so used 'full fat' contact adhesive Your ones different? Pic?
Thanks for the reply so even know they recommend solvent free you think the normal Evo will be better?
Try Unika worktop tape, I've used it with Howdens plastic edging, and finished the edge with small radius bit in palm router. http://www.axminster.co.uk/unika-heavy-duty-double-sided-tape-952233
