Hi I have an electric shower (Triton) which kept cutting out intermittently and has now stopped working altogether. I have taken the front off of the shower and have identified that the thermal cut out has burnt out. How do I go about fixing this? Can I replace the part? Do I need a new shower? Do I need an electrician?? Any advice would be gratefully received. Thanks
Hi, if your sure it's the thermal cut out switch, then yes it can be replaced, I should advise you to have it fitted by a sparks, but if you feel you could do it, I don't see why not. http://www.showerspares.com/search/...co_22009860/?gclid=CNn8kZqC170CFe6WtAodmxEAgQ
