Hmmm. I can't see - and no mention of - a joining bracket to keep the levels going in and around corners. An obvious omission? And you still have to use a spirit level. So all this is is a nice straight edge? Apply to dusty surface - come back after a cuppa - see tiles on floor...
I you just butt them up to each other and there are screw holes in the fixing brackets for extra strength. Saves on buying 2x1 for jobs every time I ordered a set last night see how they work will post what I find
Hmm, wouldn't an obvious addition be an 'L'-shaped bracket that slips into each rail end to go around, and in, corners to maintain the 'level'.
design inspired by a length of Unistrut, that often used straight edge, heavily galvanised and readily available, and just £8 for a two meter length - 'L' brackets also available to stop those corners dropping - adopt, adapt and improve
Ah, ok then....it's a good idea but a bit expensive. I've had a load of this knocking about on the van for a few years now: http://www.wickes.co.uk/planed-softwood-12x44mmx24m-pk10/invt/107002/
Well my 2x1 planed is reusable. I even leave the clout nails stuck in it!! It's a great idea and very innovative but these things always come at a price. My 2x1 has lasted me for years, costs next to nothing and when it's finally had it I use it for something else like, ermm, fixing to a wall as support for boxing round pipes or something? Sometimes I'll even chisel little wedges of the end to use as packers or for plugging a wall which is loose and crumbly and there's no other way of getting a fixing?? Extremely versatile!!
£100, Hudson?! I'd have though it would have had a clip-in spirit level for that kind of money. As well as being gold plated.
I have to agree...it does seem a lot of money for a bit of metal. I suppose they have to pay back the initial manufacturing costs and the patent fees. I'll stick with my system.
I'd have expected a hand job from the bird that's doing the voice over in the video for that sort of money.
well i have bought a kit and will see how they are this friday lol i did not think price was bad for what you get 1 x carrying tube 2 x 1000mm, 2 x 600mm 2 x 400mm 2 x 300mm 2 x 200mm 20 x clamps 200 x Heavy Duty Locator Stickers
