Hi how do I adjust these hinges please? Mainly to lift and straighten? the two large silver screws only move a few mm and appear to possibly raise/lower? Then a small Allen key adjustment in the middle of the hinge? thanks
Have you tried to gently prise off the black plastic caps on the top/bottom of the hinges, this should reveal adjustment screws.
Yes, was fully expecting to see adjustment via an Allen or hex key. Nothing there, is it possible to fit the hinges upside down? I’m not at the property at present to check.
Looking at your images, I wonder if adjustment is made using the top and bottom crosshead screws on each hinge?
