Hiya, im looking for a low voltage lighting system for a kitchen. I've seen a setup before which essentially has the lines (a bit like an overhead tramline) on the ceiling allowing you to attach the lamps wherever you want. Problem is I don't know what an earth they are called so can't start looking for them! Anyone know what they are called and where I can find them? Cheers!
Fathands, I assume you mean something like this http://shop.lightingstyles.co.uk/ceiling/track-lighting-sytems/low-voltage-wire-systems/ Regards, Snezza.
