Inlet valve Tosh.. Looks like a bottom entry inlet valve too. (does it enter the cistern via a hole in the bottom of the cistern??)
Before you go a buy a new one, double check the ballcock isn't leaking and holding water, it may be just holding enough so it doesn't raise enough to shut the valve off, had this on my mums water cylinder, the ballcock was only a year old!!
Yep. Our hosts sell bottom entry inlet valves (here) http://www.screwfix.com/p/bottom-entry-toilet-cistern-ball-valve/52836 Or possibly this one http://www.screwfix.com/p/fluidmaster-bottom-entry-fill-valve-uk/84007 Fairly straightforward to change (warning, you will get wet). PS , you may need to buy a new ballcock too.
Thanks for the advice Phil. The inlet valve has actually broken. When pressure is put on the valve button, that stops the water flow, the nipple just slides back. (hard to explain)
Thanks for the link, mate. Was just about to ask to be linked to whatever is needed for the repair. 2nd question. How best not to get soaked? lol. Mains supply off im guessing?
Either turn the mains off or (ideally) there should be a stop valve on the pipework leading to the cistern. Flush the toilet (there will be a small amount left in the cistern. This is where you get wet) Undo the connector on the bottom of the inlet valve, then undo the nut that holds the inlet valve to the cistern. Remove the old inlet valve, Put the new one in. Screw and tighten the nut that holds the new inlet vale to the cistern (make sure you've put the rubber washers supplied with the new one, in the right places) Connect the water supply back up, turn on the water, then adjust the valve so it stops filling at the correct level. Job done, open a can and relax.
Nice1 for the breakdown. The fluid Master you pointed me too earlier has good reviews and sounds easy enough to install. Does this system do away with ballcock floats?
When you've flushed and the cistern is almost empty, chuck a large towel in there for a couple of minutes, soak up until none left. No getting wet! Mr. HandyAndy - Really
Yes. It doesn't have a sealed 'ball', so doesn't suffer from that issue. Also has the benefit of shutting off pretty much instantly once the water level reaches the correct level - no more of that slooooooooowww shutting down with a wee trickle at t'end...
As DA says the FluidMaster is a direct replacement (cost a bit more though) but the fitting instructions are the same.
