I recently brought these: http://www.screwfix.com/p/easyfix-hollow-wall-anchors-8-16mm-m5-x-52mm-10-pack/12229 but didn't ask what drill bit I'll need, I'd appreciate some advice! Thanks, Shane.
I've just noticed there's a number 9 and a 51 engraved on the barell of the anchor, does this mean use a 9mm bit?
Make sure the bolt is in and just screwed to keep the length when pushing into your hole. Otherwise if your hole is a bit tight, it can bend the expanding lugs inward, and when you come to tighten it, they will try to bend inwards, which is no good. Mr. HandyAndy - Really
