I have to make a 45 degree dry wall, skimmed, meet a pine framework for doors. I'm worried that the line where the two meet will crack and forever need filling. Is there a good technique for this? I will paint the pine, but can only paint to front face if that helps? Should I PVA the right face which meets to plaster. Or is there some secret I don't know about please? See diagram. Thanks in advance!!
A beading to cover over between the two different material surfaces. Plenty available, attached to the pine and floating over the plaster join. Probably fill the small gap on the plaster side with a 'Premium' grade caulk.
Thank you. Sorry to be thick, but which beading do you mean? Just something flat do you mean? So it wouldn't be visible as it'd end before the external corner, and the caulk would cover the edge of it? If you're feeling really generous, perhaps you could link me to the beading product that you'd use in this situation. A hundred thank yous.
Yes you can buy flat, OG, astragal, hockey stick, half round, panel mouldings etc, timber merchants have a good selection even B & Q and Wickes stock timber mouldings. Pin it to the pine with a small overlap over the plaster to disguise the join line.
Could use a plaster stop bead. Take PB flush to corner of frame...screw bead on so it just overlaps onto frame then skim away. I usually scrim down the join before skimming too.
Okay - yeah - I actually thought Astramax was talking about plasterboard/plaster beading like this, not wooden beading - that's why I was confused at first. Thanks.
This is one way of doing it... http://www.wickes.co.uk/Wickes-Thin...dm|pcid|102693174052|pkw||pmt|{BidMatchType}|
Thanks, it's just that this has a 135 degree outer angle (see plan view on diagram), so there'd still be a 45 degree, triagular gap, and in it, plaster/skim would still be up against wood.
It's just a cupboard door, not a big walk-through door. There's no architrave. Just 20mm pine cupboard 'sides'. It is awkward though - you're right about that. :-/
Is there any way of bringing the frame forwards or setting the wall back a little so that the two corners don't meet at the apex? That would then be simple to fill with caulking.
Yes. Instead of cutting the plasterboard at 135/45 degrees, I could keep it at 90 (which would be way simpler anyway!). There'd then be a 45 degree triagular gap between the end of the plasterboard and the side of the pine. When the skim is done, that gap could purposely be left there ready for filling with caulk. Do you think that'd work okay?
That looks smart interested in how that is done. Probably need frog tape then caulked over which makes a nice joint. Trial on scrap maybe, wait till sospan replies
I think what he is suggesting, and what I'd do, is to butt the stop bead against the timber, then plaster up to the stop bead, which will leave a small groove between timber and bead, which you can leave as a feature, or fill with caulking. Or you could put a length of dowel against the frame, then 12mm stop bead,then plasterboard. I think it's better to make a feature of the join rather than just plaster up to the frame, although that might be ok if the plasterboard is securely fixed to the frame.
Yes...basically that. Often use stop beads on to door linings when not convenient to use archy If it's setup up correctly, with stop bead on t'other side and head, would look quite slick. Not sure if OP knows what a stop bead is?!
