Hi, I am intending removing a load bearing internal wall and looking for a supplier for the flitch beam that will be required. I had a structural engineer work out all the necessary calculation and I now just need to know where to buy a flitch beam from?
Trying to remember back more than a decade when I had a few of these fitted. I think the builders chose flitch to be lighter and easier to handle than steels. I also think I recall them bolting them together on site - the steel plates arrived pre-drilled (I think) and they used this as a guide to the holes through the timbers. So the whole thing was easily handled by two folk. The timbers would likely have come from a local builders' merchants, and most likely the plates too. On the same Ind Estate there's a metalworks so they could easily have drilled the plates for them - although there's a chance these holes were done on site too by our builders. Bottom line - if you go to a builders' merchants and ask, they will tell you what to do; you won't be the first to order a flitch.
Metalworker for the plate, a couple of extra timbers on the timber order. Note that plates are not standard and your SE should have given you a detail showing plate size, hole size and locations.
