I'm looking to tap into the cold supply feeding the boiler to run a length of 15mm to supply a dishwasher. Looking at the boiler I can't be sure which is the cold supply? Can anyone tell me which it is?
Boiler make & model? 537,532 pipe arrangment are all the same. Cold feed is 15mm pipe, 2nd in on right side,see page 15 of manual below. Installation manuak is here: https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwidtKbyhJDVAhXnJ8AKHYwwBzMQFgg4MAI&url=http://www.freeboilermanuals.com/assets/pdf/British-Gas/532,537%20&542.pdf&usg=AFQjCNGdu0eLkoZXoC21V1hV2FQ5jhxfaQ&cad=rja
The 4th pipe from the left to right under the white filling key is the cold feed. You have a rebadged worcester 32cdi or 37cdi.
From right to left, first is pressure relief,second is return,third is cold in, fourth is gas,fifth is hot out and sixth is flow.
Thanks for the responses - Perfect all done thank you for the excellent advice and replies whether left to right or right to left
