Our garage roof is made of joists supporting boards, all wooden, and needs some woodworm treatment, but there are a bunch (~100 or so) screws protruding about 1cm down from the boards. The roof has recently been redone and I guess someone forgot to measure the board thickness when fitting it. Anyway, my plan is to cut the excess screw tips off to get a flat surface that looks better, is easier to clean, and easier to treat the wood (and will take insulation better in the future) . My questions are: 1. is that a good plan or is there a better solution to get rid of these spikes? 2. what tool would be best? It's quite narrow in between the joists and I'm not sure I could get an angle grinder flat against the board (I want to cut the screws flush). Thanks for any help. Mike
I think an angle grinder is the only way as most screws these days are hardened and very hard to saw, if on the other hand you intend to lay say Celotex over the roof timbers just leave them they will push into the insulation no problem.
True with good access a power saw makes light work of it, but if he cannot get an short angle grinder in he will not have much luck with 2ft of reciprocating saw From what he describes a hacksaw blade in a pad saw handle might be the only option to cut flush to the underside of the board, OK for one odd nail but darn hard work and lots of broken blades for the number he has
Short angle grinder only has a small amount of blade showing. Reciprocating saw has a much longer blade
Shame the roof was redone without removing the infestation. I'd remove it. But small angle grinder will do the job. It doesn't have to be horizontal to make the cuts. Or as said above, jab the jab straight up! Mr. HandyAndy - Really
Screws should come out through the orherside of plywood by approx 20mm if they are holding insulation or a membrane in place, is so leave them as this is to help the roof being blown off by wind action, if not cut away.
If long enough tap them back and forth with a hammer or use a multi tool with a decent metal cutting blade.
