Heller TriJet sds bits would be my first choice as mentioned earlier, or Bosch. You shouldn't need to push on the drill,the weight of the drill & hammer within the drill will do all the work, if you apply too much pressure, you'll only blunt & overheat the drill bit.
As others have said sds should fly in, probably stupid to suggest it but you do have the hammer action on don't you ?
Yes holes are drilled, I think the problem was I had under estimated how long a hole would take to drill so I wasnt drilling for long enough
