Should have myself clearer, nut & bolt with a round washer, & plate washers on each side. Others on here might have other suggestions.
I've purchased 2 joists, bricks and cement. I'll get the bricks down for now then go from there i guess. Side note, lots of spider eggs down there, anything safe to use to get rid of them, or just forget about them.
Get the joist in and wedge it up tight to the floor boards off the walls with some slate, you could bolt it or just nail it then, it's not going anywhere once the boards are fixed back down. I would personally have staggered the boards so that the the ends did not finish on the same joist, should be ok though, and not that easy to do with T and G floorboards.
