@WH55 it is very common for buy to let landlords to rent out homes, particularly rooms in licensed Homes in Multiple Occupation (HMOs), with less than adequate numbers of socket outlets resulting in extension leads being run around rooms with multiple trailing sockets. All these homes require satisfactory EICRs and there are additional licensing requirements for the HMOs. The local council will instruct the landlords to install additional permanent socket outlets, the extension leads are unacceptable in rented homes particularly HMOs.
I can recall 2 instances where extension reels melted due to not being fully unwound. 1 was being used by my Mum for her twin tub, and the other was in a shop next to Temple Station, which was being used to power 2 fridges
I did it myself when I was a teenager, I was working in the garage with a fan heater plugged into a partially rolled up extension lead, I have never done it again, once was enough.
Yea I think you're right. I was thinking of the kiosk to the left. It's about big enough for one person to stand in.
The fourth page of discussion about a DIYer making an unsuitable extension lead, to use for an unsuitable purpose, supplied from an unsuitable socket out. When what is really required is a new permanent socket outlet supplied from an improved electrical installation. It's a job for an electrician to sort out.
What have I started. Thanks for your help, I'll install a fused spur off the double socket in the living room then which has 2 cables 1 in and 1 out.
I have re-read, where does @Scouse30 say he was going to use a rolled up extension lead? Why does he need a plug in RCD when it is already RCD protected? I was always told not more than one wire per terminal but I see with domestic common to used three, but over three one is asking for one not to be gripped fully, so I would not put any more than three wires in a terminal. As to twin and earth in a plug, not ideal, but no reg to stop it, as long as the cable grip will allow it. Yes a plug is really for flex, but if only unplugged for maintenance can't see the problem, it gets around registering the work under Part P rules for work done in a kitchen in Wales. And we still have no idea of load, shown here the load taken by my tumble dryer running as I write, 674 watt is not really enough to worry about.
I agree with @The Happy Builder The picture of the CU shows a 100mA RCD on the incomer, and no 30mA RCD protection for the kitchen sockets circuit.
Because it is quite possibly a TT earthed installation with a 100 amp 100 mA Type AC RCD and the kitchen socket circuit does not have 30 mA RCD protection, and the original poster knows this, so is using a 30 mA RCD plug RCD for the outdoor supply. Being polite, the whole installation is a pile of tat, if it's all like what can be seen in the photos.
If he doesn’t know whether or not it’s potentially a spur off a spur, then an FCU is perhaps the safest option, irrespective of whether it’s technically essential or otherwise.
I don't think we were ever able to establish where he wanted to put the socket and where he wanted to take a feed from. Best guess is that socket in the cupboard is a spur most likely from the kitchen cct but as to if it's a ring or radial who knows. In other words, not enough information given. It's weird the CU says "all sockets" on a RCBO and "kitchen sockets" on a plain breaker and "attic sockets" back on a RCBO. If the socket in the cupboard is on a 32a radial why is it wired in 2.5mm? Cable should also be secured going into the socket.
It is completely wrong then. You should not have a radial wired in 2.5 on a 32 amp mcb. If that is the case that it is a radial you need to swap the rcbo or mcb for a 16 or 20 amp rcbo.
You may have 2.5mm spurs on a 4.0mm radial protected by a 32 amp MCB, but I really doubt this is what has been done here. All I am seeing and hearing about is a tatty substandard electrical installation that needs an electrician to tidy it up, and install additional sockets for the tumble dryer and outdoor sockets.
